Results 1 to 7 of 7
Thread: Stuff missing from Pool School
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Question Stuff missing from Pool School
    Newbie pool owner here with some observations/questions about Pool School.
    First things first. I love Pool School and this forum. Great source of knowledge and experience both easily accessed and given. Thank you!
    With that being said, I noticed some things I've learned randomly just searching other topics that I really wished I learned earlier in studying Pool School.
    1. The storing of pool chemicals - it's listed what chemicals you may use for proper pool care but nothing on its proper storage. Such as unsealed liquid bleach and muriatic acid containers. Potential killers just sitting together side-by-side unless you were told that's a big no-no. Shouldn't this be a fairly major safety issue covered in Pool School? Like a big bold hard to miss link saying "Stop and read this first!" I would of had both sitting side-by-side in the shed on the ground thinking I was safe. Instead, I would have found a shed full of dangerous gases upon opening the doors. Especially in this intense Florida sun.
    2. Muriatic Acid - How to properly and safely add to your pool. Even better would be a video demonstrating this both for above ground and in-ground pools. How about the fact that precise muriatic acid amounts are given in PoolMath but the measurements really shouldn't be followed too precisely. And that it should be dosed with a ballpark guess when pouring instead of pouring into a measuring vessel and then into the pool.
    I thing these things and probably more have become a "common knowledge" issue when they really aren't common knowledge to a pool newbie.
    I'm sure that there are more I'll notice as I spend more time reading posts.
    Or did I just completely miss these as a "read first" topic somewhere?
    Gene
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Stuff missing from Pool School
    While I agree with you in principle. Here is my take.
    ANY pool chems should not be stored in a shed in the yard. As with most chems, they should be kept tightly closed and in a cool controlled environment. That's why they are usually called tool sheds I guess.
    Not all people are as concerned with the handling of MA. Not saying it's not to be respected, but some folks go WAY overboard. With Class 4 hazmat suits and respirators and the like. I personally find no issues with pouring into a plastic measuring cup, carrying it 50 feet from the garage, down to the pool and then pouring it in, in front of one of the returns. The few times that I have encountered fumes, I did not find them all the bad.
    But then again, I'm not the norm here and my thoughts, as expressed, are my own.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    I too have no problems measuring the dose of MA into a large hospital drinking mug that's marked out in ounces and mLs. You only have to inhale those fumes once to figure out how to stay upwind of it.
    I agree that the advice on the storage of MA is needed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    There is a fair amount of information on chemical handling on this page, Pool School - Recommended Pool Chemicals
    Not to mention the warning, handling and storage labels required by law to be on all chemical packaging.
    It's valuable information and I agree that it should be listed somewhere. I stored chlorine in my tool shed for years and couldn't figure out why all my lawn tools rusted prematurely.
    Yes, there are warnings on the labels and storage information can be found online but it's the point of pool school to put all this great information in one place?
    Size: 21,000 w/SPA IG/Pebble & Hayward 400k BTU Heater
    Sanitizer: Hayward GLX-CELL-15-W 40K-Gallon Turbo Salt Cell + Bleach
    Filter: Hayward C5530 Cartridge Filter w/ 2-speed 2.5hp pump
    Cleaner: Black Polaris 280 w/ Booster Pump
    Install: Mar 2012, city water (no restrictions), Test kit: TF-100, Salt, Borate
    DFW, TX
    24,483
    Actually, bleach should not have caused your tools to rust. Muriatic acid out gassing is usually what causes things to rust. Not to be contrary, but I think that the point of Pool School is to advise how to take care of your pool and manage your water chemistry. It isn't chemical school.
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by dakhath View Post
    https://www.taylortechnologies.com/C...P?ContentID=26
    http://taylortechnologies.com/produc...lfLife_web.pdf
    How to add muriatic acid to pools safely and without fumes. - YouTube
    However, I don't do this, I measure the MA, yet pour close to the water. YMMV
    MA is like a soft drink and will out-gass, wherever it is [opened or not].... and it will rust or corrode everything. I keep mine in the shade in a protected location, but outside in the free air.
