Results 1 to 19 of 19
Thread: Hi! New Pool Owner
    Jul 2015
    Somerset, KY
    8
    Hi! New Pool Owner
    I'm a new pool owner! With an 27' above ground pool. (I think you'll see my signature on this)
    It's been a learning experience! Looking forward to learning alot! Thanks!!
    - Somerset, KY- 27' Round Doughboy pool (Century) with upgraded, easy clip liner
    - 17,500 gallons of water- Hayward Vari Flo XL Pump 1.5 HP
    - Dream line high rate,175 lb sand filter
    - Using Pool Life MDX Chlorine and Turbo shock.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hi! New Pool Owner
    Welcome to TFP!
    Check out some articles in Pool School and specifically there is an article on conversion to chlorine from Bacqua pools.
    Is your location Somerset, WI or other? It is helpful to have the state/region so we know more about how to handle pools that close or may not close or general climate differences that affect pools. Adding that to your location would be great. Good to see you already have some great detail in your signature.
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hi Minnie!
    Welcome to TFP
    Essential Links:
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Hey there Minnie
    Are you happy with the Bacquicil? A lot of folks here on this forum complain about the cost and the water quality, and seek help in getting it out of their pools.
    Either way, you'll learn a lot here. Skippy and I sure have!
    Jun 2014
    15,292
    Welcome to TFP!
    Jul 2015
    Somerset, KY
    8
    Well, so far it hasn't been bad and I really have nothing to compare it to. The water has been so soft and clear even with all the rain we just had. I had one problem where it started getting a little hazy but I used a floculant(sp) as a filter aid and redirected my valve that pushes the water into the pool towards the middle and down and it cleared up overnight!
    The other problem I had which is really not a problem was I added too much algicide once and it foams up a bit if you kick around.
    I would love to convert to a salt water system maybe next year. I heard it is less expensive.
    We have a "loaner" ladder till we build our deck and have had some trouble with it. We are trying to rectify it. The steps float till you go down the side into the pool. I guess that's okay but
    We have buried the outside part into the ground to make it a bit more stable. You think it needs weights and the pool pad some said they use here?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    You will need one of the Recommended Test Kits to properly manage your pool. I use the TF-100 because it's the best value and they have a freshness guarantee. You can order it here: TFTestkits.net. They ship fast - you should have it in your hands in 2-3 days with normal shipping. If you want to really do the right thing, I would order one of these test kits tonight. Do not rely on pool store testing - it is notably inaccurate and they will use those results to sell you all sorts of chemicals you do not need that will cost you way more than this test kit.
    While you are waiting for your kit to arrive, here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    Jul 2015
    Somerset, KY
    8
    Hi, will these tests help me with Bacquicil? That's what I'm using right now. So far no problems.
    Casey's Avatar
    SW PA
    10,461
    Welcome to TFP. We don't really see many BAQ pools because of the problems that arise from the use of BAQ. Most members get rid of it through a conversion in the BAQ Forum and are so happy to get rid of it, they never look back.
    Jul 2015
    Somerset, KY
    8
    What kind of problems? I really haven't encountered any yet......
    Jan 2012
    7,373
    Is it expensive?
    Jul 2015
    Somerset, KY
    8
    not too bad i guess. I would really like to have a salt water system. Do you all know about them?
    Jan 2012
    7,373
    I have a salt water generator (SWG) and love it! If you have questions, lay 'em on me.
    Jul 2015
    Somerset, KY
    8
    Thank you so much! I am a new pool owner with many questions.
    I would like to change my pool next year to the salt one. Bacquicl is nice but so expensive. Is my equipment and pool capable of handling it? Which one do you recommend and do you like it?
    I am going to close my pool soon and have been using baquicil. Do I need to do anything to the water and filter before closing it?
    Can you recommend a pool cover for me?
    Jun 2014
    15,292
    You'll want to read this page here: Pool School - Convert Your Baqua Pool to Chlorine. People do it all the time.
    As for the best SWG and pool cover to get, I'll let the others who have them chime-in.
    Jan 2012
    7,373
    I'm sorry I can't advise on a SWG if there are specific ones for above ground pools because I'm unsure of how the plumbing is set up on them? But I know AG folks do have them...and your pool is plenty big so you'll love how it simplifies your life.
    You want one that is about 2x larger (size wise in gallons) than your pool. My Compupool is sized for 36,000 gallons so I don't have to run it long or at a high demand % since its oversized. This helps give me a longer life span on the device at minimal increase in cost over a smaller SWG.
    You'll add lots of bags of pool salt before starting the SWG up but then you shouldn't have to add more very often as the salt only departs the pool with water exchange. I've only had to add like 40 pounds once in 3 years to boost my level. The salt makes the water feel nice and soft, just like fancy bath salts do to your bathtub. The SWG takes the salt water and breaks it down to make chlorine and then once its back into the pool it returns to salt again. Its a pretty cool continuous loop.
    Jul 2015
    Somerset, KY
    8
    Should I do it before I close it up for the winter or wait till spring and maybe just change the water?
    Jul 2015
    Somerset, KY
    8
    Hi Thanks! Sounds nice. Who is "AG"? Do they sell them on a website for above ground pools?
    Should I convert my pool from Bacquicil before I close for the winter or wait? Is it more effective to just change the water? The pool people left some wrinkles in the liner when filling the pool and the sand underneath is lumpy. I think from all the rain. Don't know if that hurts the pool or not. Any advice there?
    Also looking for advice on a pool cover for the winter.
    Jan 2012
    7,373
    AG=Above Ground Pools....sorry for the confusion.
    As to conversion to chlorine, its your call....but I think it would go quickly if you did it when there is the least amount of Baqacil in the water. Would that be more likely next spring, or is it already pretty low now?
    Check this board out - Baquacil - Use and Conversion
