Thread: Too much chlorine to swim?
    Jul 2015
    washington, pa
    8
    Good Morning,
    This is my first year with a pool. My levels are below. I took a reading this morning.
    PH 7.8
    FC 10
    Alkalinity 120
    Stabilizer 30
    When is it safe for my daughter and I to swim?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Too much chlorine to swim?
    Hi, welcome to TFP! Your pool is safe to swim now. You have a CYA level of 30, so your FC shock level is 12ppm, and your recommended target range is 2-6ppm. As long as the water is clear, and you have FC between 12ppm and 2ppm of chlorine you are safe to swim.
    Love TFP? Become a
    TFP Supporter!
    Sep 2013
    Connecticut
    728
    See here
    Pool School - Chlorine / CYA Chart
    Anything below shock FC level is safe for swimming. That assumes, of course, that your measured values are fairly accurate. What is the source of the results you list?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jul 2015
    washington, pa
    8
    Thank you for your quick reply! I do just have the test strips...nothing too advanced so it only goes up to 10...it is the same exact color as the purple on the 10 though...still okay? (I'm a worrier!!)
    Sep 2013
    Connecticut
    728
    Given that you are using test strips, which are not very accurate, you have to be skeptical of both your CYA (stabilizer) and chlorine results. Since chlorine is apparently measuring at the top of the scale for the test strip, it might actually be well above 10. I would wait to swim until it tests below 10.
    In terms of successful long term management of your pool, I'd suggest doing some reading in Pool School, so you feel more familiar with the various chemical parameters and how to manage them yourself.
    What size and type of pool?
    Jul 2015
    washington, pa
    8
    30 ft round above ground
    Thank you!
