Thread: Aqua Rite reading zero salt
    Jul 2015
    Slidell, la
    1
    My system was reading zero salinity, I cleaned the cell and system still reads zero. Went thru reset and still no change. Any ideas?
    Re: Aqua Rite reading zero salt
    Try the following
    1) Turn the switch to Off.
    2) Push the diagnostics button and record all of the readings
    2) Wait 5 minutes
    3) Turn the percent to 50 %
    4) Move the switch to auto
    5) Within 30 seconds, you should hear a click.
    6) Wait 30 seconds more
    7) Push the diagnostics button and record all of the readings
    Then repeat the above procedure again.
    This will give you 4 sets of readings. Post the readings, the measured salt level and the make and model of the cell, and we should be able to help.
    Support the site
