Thread: Found dead rat in pool
    Oct 2013
    Los Angeles, CA
    87
    Found a dead rat in my pool is my eater safe ? What to do now ?
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Found dead rat in pool
    If you are maintaining it properly, its probably fine.
    test the FC and raise it if its low. Also check for CC.
    If you are really worried, raise it to slam level for a day or so and it should be fine.
    Divin Dave,
    Jul 2014
    Hope Mills, NC
    567
    Found one 2 weeks ago in mine, not only that, but he baby ruthed all over the steps. Cleaned up the dung with the vaccum and went swimming. I keep my FC high enough not to worry too much.
    Wow cant use any word for solid waste!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Oct 2013
    Los Angeles, CA
    87
    Thank you for the reassurance my pool is on set and my fc is at about 6 or 7. I will probably buy a three pack of chorine and dump it in there
