Thread: Best pool cleaner for in ground vinyl pool
    bell7401's Avatar
    Jun 2015
    Houston, tx
    11
    Just curious what you guys might recommend as a good pool vac for an in ground vinyl pool? It will run thru the skimmer line. We do not have a separate line for a vac. Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Best pool cleaner for in ground vinyl pool
    If you don't have a dedicated suction line, I would strongly consider a robot cleaner rather than a suction cleaner. Independent of your circulation system so it saves pump run time, you can clean the pool without the pump running. I've heard good things about the Dolphin Nautilus & Nautilus Plus. I have a Hayward TigerShark that works well but I'd rather have one with a top loading filter, which my next robot will have.
    If you want a suction cleaner, ThePoolCleaner gets lots of recommendations here on TFP. POOLVERGNUEGEN Manufacturer of the finest automatic swimming pool cleaners -- The PoolCleaner
    Isolated Spa - 345 Gallons
