Results 1 to 11 of 11
Thread: pool math?
    Jun 2014
    Central Maine
    21
    pool math?
    The fc, ph etc. target goals are "not set up" in my pool math.
    Everything was fine earlier this year so how can I reset and save them?
    12,500 gal. AG---extruded alum. with 1hp Hayward EC-50, D.E. filter ( both 30 yrs. old)--Taylor TF-100---well water
    Jun 2014
    15,298
    Re: pool math?
    Humm. Well, not sure if this is a computer cookie or cache retention issue, maybe one of the Admin folks will confirm. But I was in Poolmath last night/this morning as well. Depending upon how long ago I was in the calculator, or which computer I am using at the time, I may have to re-enter my NOW and TARGET goals, as well as my pool volume size. Not so sure it is able to save your parameters for such a ling time.
    May 2015
    Chicago, IL
    508
    Re: pool math?
    Yeah it looks like it is cookie based, I assume the server switch may have affected it. By entering the info again, it should save it.
    Jun 2014
    Central Maine
    21
    Re: pool math?
    ok, so I just deleted all values to "0" and rebooted. I then input the current info and target. Still showing "not set up". Apparently it is a computer issue that I need to correct right?
    May 2015
    Chicago, IL
    508
    Re: pool math?
    Seems to be storing the numbers for me, but I have not used the pool math much at all, so I am not sure on it's full functionality.
    30,432
    Re: pool math?
    My experience with PoolMath is that it will default back to most settings you input. Not specifically to "save" them but just as a default. Gallons is the only one I really need because of the way I use it and the last value entered in gallons seems to be there next time.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: pool math?
    'Not set up' refers to the setting near the bottom of the pool math page.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    Chicago, IL
    508
    Re: pool math?
    Those always have stored what I entered, for all three values. But if it is like you go to the page for the first time, all the items will say Not Set Up.
    Jun 2014
    Central Maine
    21
    Re: pool math?
    got it! I needed to input the my info at the bottom of the page (suggested goal levels). Thank you pabeader and others.
    May 2015
    Chicago, IL
    508
    Re: pool math?
    Awesome, glad to hear it's sorted.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: pool math?
    You might be able to save the page to your hard drive and have it retain your info better.
