Thread: Pvc pool cooler/sprayer/waterfall, do we need to worry about algae?
    Apr 2015
    Waterford, MI
    133
    If you have one of those DIY pvc sprayers and rarely use it, could it be a spot for algae to grow?
    Michigan - 24'x54" AG, approx 15,000g, 2 center drains, Cartridge filter, Aqua Pro 2hp, 2 speed pump 3.5a@1725w / 10.5a@3450w, AquaCal TropiCal T90 heat pump, Hayward Salt & Swim SWG, Poolskim, Aquabot Rover Jr.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,379
    Re: Pvc pool cooler/sprayer/waterfall, do we need to worry about algae?
    I forgot to open my bottom drain valve one time after putting my cleaner in. Within a week I noticed my pool had lost some sparkle. I did not pass a OCLT. What was going on???????????
    As soon as I realized the bottom drain was not open I figured out that there was water just sitting in the drain and pipe that was getting nasty! I was about to have an algae bloom!
    I opened the valve and used my turkey baster to shoot some chlorine down into it!
    I SLAMed for 3 days just be on the safe side. No more problems.
    All of that to say that yes anything that is sitting with water in it not moving can cause problems.
    Kim
