Thread: i assume its normal to loose 3ppm of chlorine is heater is on high?
    i assume its normal to loose 3ppm of chlorine is heater is on high? in a day
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: i assume its normal to loose 3ppm of chlorine is heater is on high?
    It is normal to lose 2-4ppm of chlorine per day in most pools
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    And it's normal to lose FC faster in warmer water.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    And if you're heating it, there's probably people in it, which also uses a lot of FC.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    My pool isn't heated, and is about 80 right now. It was 84-86 before the rain and cooler weather the last week. I'm losing just shy of 3ppm a day right now.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    It's also a function of your CYA level. If you have a lot of sun on the pool all day you might consider raising the CYA, especially to 50 ppm if you aren't there already. In very hot sunny climates such as the desert, people go even higher in CYA level (but not above 80 ppm since a SLAM becomes more difficult at that level).
