Results 1 to 15 of 15
Thread: Adding muriatric acid
    Jun 2015
    Wamego/KS
    120
    I have used pool math to determine amount of acid to add to lower ph from 8.0 to 7.4. Any tricks to adding the acid? Do I need to add it and then let the pump run for a min time?
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Adding muriatric acid
    Hi Nate,
    the best way is to slowly pour the acid in front of a return with teh pump running. If you have several returns, then spread the love!
    After 30 minutes iwth pump running, test again to make sure you hit your target.
    This goes for any liquid chemical you might add.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Here is a handy page about Pool School - Recommended Pool Chemicals and how to add them.
    Also, with MA be sure to keep the bottle downwind from you, the fumes are pretty obnoxious.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    I have found the best way to add MA is to make it a 2 person operation. One person pours slowly into the water flow of the return while the other person brushes it around so as to mix it quickly in to the water. By itself, MA is pretty caustic. Once well mixed/diluted in water it isn't as scary.
    Jun 2015
    Wamego/KS
    120
    So...after 30 minutes kids can swim?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, thirty minutes is more than enough time to let them swim after adding acid.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    Tricks? Sure.
    1) Don't wear good clothes
    2) Stand upwind
    3) Don't set the bottle down on concrete unless you've rinsed it by dipping it in the pool first. Sometimes small dribbles collect and they will leave a nice white ring where the jug was.
    4) Lean out as far as you can over the water in front of a return, pour the acid into the measure, then pour the acid slowly into the return stream. Rinse the measure in pool water. I find swishing water around and then pouring it right into the acid cloud helps disperse it. A couple quick rinses and you're done. Takes longer to type it than to do it.
    Mar 2007
    San Rafael, CA USA
    12,082
    And last but not least is to lightly brush the side and bottom of the pool in the area where you added the acid. Technically if you were really careful and slowly added it to a return flow, it probably get well dispersed, but if you missed the flow or added too quickly then some acid could drop below and since it is heavier than water until mixed, it could pool at the bottom. Brushing ensures that there is no pooling and also helps circulate water near pool surfaces (including walls) where technically water flow rates go to zero.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    When adding MA i scoop 5 gallon bucket water from pool and add right amount of MA to bucket then pour around perimeter of pool then use 24" wall brush to stir it around while pump is running.
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Everyone has their way of doing it..... I like to get in front of a return on my hands & knees and splash a little water on the pool deck. Then open the acid bottle and partially submerge it in the water. Tilt the bottle to pour the acid in at close to water level, but don't let the bottle get submerged.
    I don't measure because it's an additional step for me to spill the stuff. Remove the bottle from the water and set it down in the puddle on the pool deck while you replace the cap. Try not to breathe the fumes.. Guess a little low on amount you need, then test again after it circulates well. You can always add more.
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    i pour it into a measuring cup, then just spread it around near my stairs. it helps keep the metal stains off the stairs. i'm lucky, the fumes don't bother me. not the suggested method, but it works for me.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mar 2007
    San Rafael, CA USA
    12,082
    Even diluting Muriatic Acid in a 5 gallon bucket and distributing around the pool, I would still brush the pool where you've added it. Adding even just one cup of Muriatic Acid into 5 gallons of pool water still has the pH of that water be less than 1.0 (because full-strength Muriatic Acid has a pH of -1.0 and you dilute by less than 1/100th).
    Jun 2015
    Wamego/KS
    120
    I have 3 returns so I just poured a little in at each one. I then brushed the pool good. I did get a good whiff of the fumes on the first return...won't make that mistake again! Thanks for all the advice.
    May 2015
    Miami, Fl
    47
    Wear eye protection. I had a drop splatter in my eye and ended up in the ER. Thanks God no permanent damage.
    Built March 2015 13000 gallon free form exposed aggregate with sheer descent, Jandy 2HP VSP, Jandy 1400 SWG with Aqualink PDA and AquaCal electrical heater. Pentair Clean and Clear filter 150SF. TF100 test kit. Pentair Kreepy Krualy Great White.
    Jan 2012
    7,306
    Quote Originally Posted by pabeader View Post
    I'd go careful with that. I have a small spot on the floor of my fiberglass pool right where I pour the MA in (before I learned to brush it immediately and to be so very very cautious of it) that I attribute to MA. I also had a small incomplete hole in my cement deck appear after a couple drops landed on it.
