Hello,
I have a Zodiac MX8 pool cleaner which was running fine till a few weeks ago. A few days ago the wheels on one side of the cleaner stopped turning and the pool cleaner stopped running completely. When I pick up the pool cleaner both the paddles below the pool cleaner turn vigorously. I tried replacing both the tracks but that did not help either.
When I remove both the tracks the side drive shafts turn continuosly.
Then I removed the track on the left side and noticed that wheels on both the sides turn normally. But when I put in the track on the right side then pool cleaner stops moving. I am not sure why adding the track on the right side will cause it to stop turning. Any helps on debugging this further would be useful as well.
