Zero pressure in my cartridge filter
mknauss
47,912
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Welcome to the forum!
I assume it is not normal after cleaning the filters to have low pressure?
The filters may not be properly installed and allowing water to bypass going through them. Filling out your signature with your pool type, size, equipment, etc helps us help you.
I suggest you read ABC's of Pool Water Chemistry.
Texas Splash
37,553
Fiberglass
CircuPool RJ-45 Plus
My pressure gauge sits near zero all the time when on low speed. On high is goes only to about 6-7 and finally about 10 or so when I need to clean it.
Welcome! :wave:
jvec
4
Fresno, CA
Hi, Thanks for your respond. That was my first thread. I didn’t know how to reply back. Anyway, that filter and pump were installed over 3 years ago. The whole time was fine until 2-3 weeks ago. It happened suddenly. When I looked at the pressure 2-3 weeks ago and found zero psi. I thought faulty pressure gauge so I bought a new one and replaced it. I also washed the filters same time. I cleaned the pump basket. But still zero psi after all done. Thank you for your help!
pool size 17000 gal3EED0D33-9CCF-48EF-AE1A-D592F7AC8AAE.jpeg77B18D11-CFB5-4412-8A02-939FF9FDFA31.jpeg4F66EDDB-8F44-44B0-B3F6-2F4538E26BD5.jpegB022C184-5FA5-4B14-B3AA-D4796235F8CB.jpeg70A17F7F-FE77-4EBB-BF80-D3AF06E7E2E4.jpegD15A4BE2-C8E0-4257-84D3-A216D76DF025.jpegA32B5133-26C3-472E-A9D2-53CDACD8B396.jpeg55792988-0A5D-4A4E-9D0C-3A7DF9193788.jpeg3C24C9EF-F035-4333-82FD-9C3F2C5C4DAC.jpeg
Jimrahbe
25,944
Bedford, TX
J,
If the flow back to the pool feels normal, then it has to be a gauge issue. Since the gauge itself is new, then I suspect that the small hole that goes between the gauge and the inside of the filter is clogged. Take the gauge out and run water through the line under the gauge forcing it back into the filter.
With a single speed pump, your gauge should never read zero when the pump is on.
jvec
4
Fresno, CA
J,
Jim,
Pressure gauge and air bleeder are one piece. I replaced the whole set new including small hole.
