Yellow Tint in Deep End
SPKNout4CHRIST
262
Goldsboro, NC
Our pool just finished filling today (municipal water) after a new liner installation. Ever since it had a good amount of water in the deep end it has had a yellow/green tint to it. The shallow end looks normal. I have attached a pic of salt in the deep end. You can see the main drain and salt look yellow/green. The pool store tested for metals and everything came back 0ppm. Latest test results are below. Thoughts?
FC - 3
CC - 0.5
CYA - 0 (added enough to get to 40 and will then add more to get to 70)
Salt - 0 (added a little more than half that is needed)
pH - 7.2
TA - 40
CH - 25
jblizzle
43,238
Usually a yellow tint to new water is iron, often made worse when adding chlorine.
What brand of salt did you add? There have been more than a few reports of the Clorox Pool Salt causing iron staining due to contaminants.
SPKNout4CHRIST
262
Goldsboro, NC
Diamond Crystal yellow bag. It had that tint to it prior to adding the salt.
It’s odd that it would just now start having that tint with that water source. It is the same one we have used for 9 years.
If it is iron, is it something the filter can catch without me adding anything else to the water? The reason I ask is because the filter has only been running 2 hours with this new water, so I know it hasn’t had time to turn over completely yet. Just wondering if it is usually caught by the filter and that’s why I’ve never noticed it.
jblizzle
43,238
If the water is tinted, then the iron is oxidized and out of solution so the filters can usually capture it. Some members put polyfill in their skimmers of rig at a polyfill filter system to put the iron out.
SPKNout4CHRIST
262
Goldsboro, NC
I’m happy to report that the water was clear this AM. I put some polyfill in the skimmers. They didn’t seem to have a color to them, but the water is clear nonetheless. Thanks again for the help!
