WTB the right 2 inch pvc coupling?
pcm2a
225
Mt Juliet, Tn
My pool system has many couplings on it. All of them are 2 inch couplings and 3 inches long. I went to Lowes, looked at everything they had and even asked the guy and the only 2 inch coupling is 1.75 inches long. I'm not sure I'm confident in using that. Is the only place to get a longer one the pool shops? I did some google searches for "pool 2 inch coupling pvc" and couldn't come up with it. Leads me to believe my search term is no good.
If that is plenty big, then my next concern is it's an extremely tight fit. I'll have to hammer on it if I wanted it seated all the way. I'm not sure I'd be able to get it seated and turned to the exact spot before the cement was hard. When I've installed check valves and unions it's always slid in real easily.
Randrx2
363
Orlando, FL
Your existing coupling is a “deep” or “long” coupling. Probably not at the typical big box stores. Maybe Ace Hardware? You can also try counter sales at a plumbing supply house. Last option is to just order online.
When you are saying hammer on, is that when you are trying to fit up dry? It should slip in once you have the glue on it.
The deep couplings give a little extra support and also help correct goof ups.
pcm2a
225
Mt Juliet, Tn
Yeah dry fitting is when it is tight. I don't see how I'll ever get it to line up with my union going to my filter without a dry fit. And your also right that my "straight" cuts are not straight. This is also on the output of my pool pump if that needs some extra support.
I wanted to give it my best shot before having a pool place come out and charge $200 to do it for me.
ajw22
18,163
Northern NJ
I think you have a DWV (Drain Waste Vent) coupling intended for non pressurized plumbing not a coupling for schedule 40 pressurized applications. Some folks get away with using DWV stuff from the big box stores. But it is not what pool builders use.
pcm2a
225
Mt Juliet, Tn
In my picture? Yeah, I put that on just to check for other leaks and to run it for a little bit to get some bleach through. Under it my pipe is already cut some. It will be replaced with the coupling as soon as I have the right part. It would eventually blow apart by the way it balloons out.
Is the short coupling safe to use on pool applications?
JamesW
19,456
They have the right couplings at Lowe's.
They are in a section near the dwv.
Go back and find the schedule 40 fittings.
JamesW
19,456
No. That's conduit. In the plumbing isle, they have schedule 40 pressure fittings that look like your existing fittings.
pcm2a
225
Mt Juliet, Tn
I looked at every box on that isle with the white pvc pipes and on the website. If it's there it's hidden well. Search for 2 inch schedule 40.
JamesW
19,456
Lowe's and Home Depot have the right fittings. Ask someone who works there. If they say that they don't have it, ask someone else.
JamesW
19,456
Lowe's
LASCO 2-in x 2-in x 2-in dia Coupling PVC Fitting
Item # 23902 Model # 429020RMC
Lasco part number 429-020.
JamesW
19,456
A Lasco 2" long socket coupling (428‐020) is 4" long.
A standard socket coupling(429‐020) is 2-7/8" long.
pcm2a
225
Mt Juliet, Tn
Installation went fine. Anyone that says it will "slide right in once the primer and cement are applied" is one hundred million trillion bazillion percent wrong. It would not slide right in. Luckily I planned for this and had a rubber mallet beside it. I used the mallet to hammer it down on there. Good thing I was able to do it quick enough before it was stuck. I somehow also managed to line up the union perfectly.
Randrx2
363
Orlando, FL
Sorry about that. That’s odd. Maybe the pipe swelled a bit from being in the elements. Or it had some dirt buildup? Not sure. Usually it fits right on with a little effort, but not having to hammer on with a mallet!
pcm2a
225
Mt Juliet, Tn
You know, you might be right about that. In the store I bought an extra 2" pipe for something else and when I left the store I stuck the coupling on the end. It only slid in about 10% but it did slide in that far easily. On the existing pipes it wouldn't even slide in 1% without force.
