Wrinkles in new liner. How do I fix
You may need to drain the pool and work on the liner with it empty then :(
Did they use a shop vac to help suck the liner up to the wall?
Is the signature at the bottom of your post your current pool? I am guessing not as it is listed as being plaster.....can you please fill in the info for your current pool? (Go up to name, click on it to pull down box. Click on Signature). Put in kind -plaster, vinyl. Size in gallons, equipment especially filter kind-sand, DE, cartridge. How you are testing your water.
Kim:kim:
