We have an all tile pool, built in 1932. We need to do various repairs to the pool (although it has held up great). One of those repairs includes the pool ladder. We are wanting to retain the (4) all brass steps which were original in the pool, and somehow affix them (braze ?) to a new pool ladder made from 2" Diameter (OD) x 1/8" thick brass tubing. The original ladder was made of steel, and rusted out after so many years. We believe that the original steps were saved and brazed to brass in the 1980's. However, the ladder has disconnected from the wall, and since the prior repair only featured cutting the original above-water galvanized steel, we now want to replace the entire assembly. So I have a couple of questions for any contractors familiar with metallurgy:
1) The brass tubing we are considering is roughly 65% copper and 35% zinc. Would this be OK long term for corrosion resistance? (We have no idea of the actual percentages in the alloy of the original "step" pieces.)
2) Since stainless steel seems to be the modern-day standard in materials, is it feasible to join these original brass steps to new stainless somehow ?
3) Are there any companies out there who anybody can recommend for bending brass tubing and brazing original steps?
Thank you so much. The pool is historic, and in 1981 we replaced a 5hp single pump and (3) MASSIVE sand gravel filters with just (2) Purex "grid" DE filter tanks, and (2) 2hp motors. We'll be getting variable speed pumps and cartridge filters, as well as adding in-line skimmers, which to this day have always been external stainless "boxes".
