Installing new AquaPure 1400 in an AquaLink RS control box. Instructions say to connect SWG transformer (it must weight 25 lbs!!!) to 240v pool pump relay. That makes sense as it will only run when pool pump is on. But my pool heater (standard Pentair gas unit) is already taking up the other side of the 240v load lugs. It seems it's a good idea to synch the pool heater with the filter pump too (ok, makes sense, heater only runs when pool pump is on).
But how do I (mechanically/physically) hook a third 240v load on this relay? Is that really a good idea? What if I have all three going at once? Will that overload the 120v lines coming in? Will it burn up the relay itself? And if all that is ok, how do I physically hook the third wire in? Is there a special lug I can screw into the current lug spot that adds a third wire spot?
This is not my box but similar 240v relay with wires on both sides of lugs. How do I get a third wire on there?
All ideas and work arounds welcome.
Ken
Ken
