Wiring new pool pump
matt4575
6
Florida
Hayward Aqua Rite (T-15)
I have a new 2HP Century 1081 pool pump and need help wiring please. The old pump had a red wire on terminal # 2, the black wire on terminal # 3/4 and blue wire on terminal #1. The new pump is labelled different with L1 = HI, L2 = Com and A= LO. What wire goes where?
matt4575
6
Florida
More information to share - power is 230V. Image on new pump terminals attached.
matt4575
6
Florida
Matt,
We need to see the connection label on the side of the old pump.
Jim, I do not have that pump. I did post the way the old motor was wired
Jimrahbe
22,612
Bedford, TX
Matt,
Thanks for the pic...
On your new pump L1 is Red High Speed, L2 is Blue (common) and A is Black for Low Speed.
matt4575
6
Florida
Matt,
Thank you so much Jim
matt4575
6
Florida
Jim, when you look at both name plates, does the new one look like a direct replacement?
Matt A
Jimrahbe
22,612
Bedford, TX
Matt,
I am "assuming" that your original pump ran both high speed and low speed that is being controlled by some timer or switch... If that is true, then the new pump should operate the same way.
