Wiring a 2 wire from a Pentair Mastertemp 250 to a Pentair Easytouch panel
G'sPOOL
In The Industry
Aug 19, 2019
5
Southgate, MI
I think I did this right, but I dont't think I can test until my pool is filled. I cut the yellow jumper cable and hooked it up to a 2 wire and run it back too the Easytouch. Can someone confirm this as the dirrections aren't very clear. Also does anyone have any pictures of how and where they ran that cable out of the heater back to the Easytouch panel since it's not going in the conduit.
Thanks!
Jimrahbe
15,085
Bedford, TX
G,
Not sure about your description, but if you basically replaced the yellow jumper with the Gas heater connection (relay) in the EasyTouch, then that sounds correct to me..
When the heater relay closes, it does the same thing that the yellow jumper used to do, and allows the heater to run...
Reactions: G'sPOOL
