Winter Water Temperature and Pool Chemical Balancing
JPMorgan
198
Elmhurst, IL
How cold does pool water get in winter temperatures in the north. I played around with Pool Math and noticed that at my current water temperature (about 70 degrees) and current readings, everything is in good balances (CSI = -.05). However if I drop the water temperature in Pool Math to 30 degrees I get a CSI of -.44 and at 10 degrees I get a CSI of -.66, which is out of safe range. Should I make adjustments to chemicals before closing to account for the colder water temperature and if so what temperature should I expect the water to reach if air temperature goes below 0.
JPMorgan
198
Elmhurst, IL
We have owned the pool for about 25 years and have never had it re-plastered. The pool had a painted surface when we became the owners and we have continued to paint it (every 5-6 years) with an epoxy paint.
JamesW
19,337
I would just let the pH get to about 7.8 and you should be good.
Paint is not the same as plaster. Paint might have some calcium carbonate filler, but I don't think that it needs the same CSI as plaster.
In cold water, all reactions slow down.
