Hi everyone!
Sorry this is a topic that has been brought up again and again, and after reading through many posts and forums I still haven't found a convincing explanation that also fits what I've seen pool professionals do. This year is the first I've decided to close the pool myself so I am kind of worried that I'm missing something. Here is the process I've followed:
1. Lower pool water level below returns: I've read various opinions on this. In principle it seems that you don't need to do this, you can just blow air and while doing that insert the plugs. I was a bit scared of doing that so I decided to play it safe and lower below level of lowest return.
2. Blow water out of all lines. I used a 3.5HP wet-vac for this and it seemed to work just fine. I had a compressor ready but it wasn't required in the end.
3. Remove drain plugs from pump, filter and water heater.
4. Plug winter rubber plugs into returns (my pool has 3)
5. Plug winter rubber plugs into the 2 skimmer holes (one goes to pump, the other one goes to pool main drain)
6. Place winter mesh cover.
My doubts are mainly with step 5. While doing this I realized the pool water level is not lower than the bottom of the skimmer. This means that without the plug the water will come up and fill up the bottom of the skimmer.
Question 1: Is there a chance water can leak out of the drain pipe through the rubber plug and fill up skimmer bottom? The plugs seem in good shape (I cannot see any cracks) but in this case there is water pressure from the pipe upwards and I'm not sure if the plugs are designed for this.
Question 2: Rain water/snow can still fill up the skimmer with water (see picture of skimmer hole with the plugs after some rains we had in the last few days). I have read that this is not good and people use gizmos or RV antifreeze, but I'm pretty sure the folks who closed the pool previous years didn't do anything special about this. Is there real danger of water freezing inside skimmer hole and damaging it? How do I prevent this from happening?
Bonus question: Is it really necessary to lower the water level below the returns, or is it fairly easy to insert the plugs while blowing air and still get a good seal? I was scared this wasn't going to work well with my wet-vac.
Thanks so much!
Thanks so much!
