Hi TFP,
If the water is flowing the direction of the arrows what happens with the water near the check valve (circled)? I have two stenner pump chemical injectors and will they mix with the water or is this a problem where they are located? The nearby flow switch shows not enough flow is happening even at high pump speed.
Thanks for helping,
AJB
Thanks for helping,
AJB
