WiFi master temp 125
UKjames
238
United Kingdom
The Pentair IntelliConnect is a relatively inexpensive app-controlled option. You can connect up to 5 devices. It will not control valve actuators. Cost in US is about $275 +/-. You would need to install a temp probe.
thanks. Any idea why it doesn’t interface with the heater temp reading? Can you use it to change the target temp on the heater
Rancho Cost-a-Lotta
3,980
Rancho Cucamonga, CA
CircuPool RJ-45
I wondered the same thing. Seems it should be possible since the heater monitors temp anyways. I probably would have bought the unit if it had Alexa control. For me, the ability to schedule and control VS pump settings is appealing.
UKjames
238
United Kingdom
No, you set the heater temperature to max and let the Intelliconnect cycle the heater to its set point.
Thanks for explaining. So does that mean the interconnect controls the main power to the master temp and kills it when it reaches temp/turns it on when too low.
I ask since I noticed my heater has a bit of a wind down cycle before switching to stand by when it reaches temp (well the fan runs a bit longer). Does that mean it’s ok for that fan run on not to happen?
ajw22
38,873
Northern NJ
Pentair Intellichlor IC-60
No, the Intelliconnect controls the heater using what is called the "Firemans switch". It is a low voltage connection that is like pushing the off and on button.
Reactions: UKjames
UKjames
238
United Kingdom
That’s great thanks Alan. I think I will get a WiFi switch/relay.
I tend to try and swim at the same temperature. Now the weather is colder I need to put the heater on a bit sooner or sometimes it’s still running when I’ve finished my swim so I need to turn it off but currently have to open the shed with the pad in and then turn the temp down or heater off. Then next time have to go back in to turn it on.
given I’m setting the heater temp to a sensible swim temp rather than max I think whilst handy, the automatic thermostat feedback whilst nice to have isn’t going tob be essential. I can do it manually via a separate WiFi thermometer or if my programming skills were up to scratch use some Python to get automatic feedback.
I currently have the pump and heater on WiFi switches that have load sensing so I can tell when the heater is running as the fan increases the load above the standby load.
ajw22
38,873
Northern NJ
Where do you usually put the temperature probe, is there a fitment that is part of the pad plumbing, strapped to the plumbing or in the pool itself?
Drill a hole in the PVC between the pump and the filter and secure the temperature probe in the pipe with a band clamp. The installation instructions should cover it.
