A,
I need pics of the inside of the time clock controlling the pump.. I need to see where the wires on the inside go.
You have three valves on your return line... Return, Spa, and Waterfall.. If you want to control all three valves, you will have to get creative if using an EasyTouch (ET)
An EasyTouch only has two user programmable valve drivers.. So your options are:
1. Buy a single body ET4... Leave the return valve open all the time and add an actuator to the Spa valve A and the Waterfall valve B.. The problem with this option is that you will most likely have to run your pump at close to full speed to have your Spa or Waterfall work.. and I really doubt that you would be able to run your spa and waterfall at the same time.. You would still need to buy two actuators...
Ref...
Pentair Easy Touch Control Base System 520591
2. Buy a dual body ET4.. You could then have all three valves controlled by actuators.. Spa valve A and Waterfall valve B, and by putting the system in the "Spa" mode, you could control your Return valve. This unit comes with two actuators, so you would only need to buy one more.
Ref..
Pentair Easy Touch Control Base System 520538
To make the EasyTouch easy to program and use, you would need ScreenLogic...
Ref...
Pentair ScreenLogic Interface and Wireless Connection Kit 522104
I suggest that you operate the pool without an automation system for while and see what you really use and what you do not use.. Waterfalls sound great in theory, but very often they are very noisy and it is like living next to a freeway..
I think we can get you running manually and this will give you a chance to evaluate what you want/need...
I am "assuming" that the salt cell is being provided by the pool builder.. If not, then let me know as ET's with included salt systems have different numbers (and pricing)
As much as I love my EasyTouch, I would be remiss in not having you look at the new Pentair IntelliCenter automation system, which is better and has many more options..
Jim R.
