Our "pool guy" is planting seeds to convert our salt pool back to chlorine. Some of his reasons are: salt is corrosive, salt requires more expensive equipment, etc.
What are your thoughts?
A salt pool is a chlorine pool. Maybe time to consider converting the pool guy into an ex-pool guy.Our "pool guy" is planting seeds to convert our salt pool back to chlorine.
Hi, and welcome to TFP!Our "pool guy" is planting seeds to convert our salt pool back to chlorine. Some of his reasons are: salt is corrosive, salt requires more expensive equipment, etc.
(2)Most saltwater chlorine generator (SWCG) pools appear to remain algae-free at a lower minimum FC level compared with the minimum FC column for manually dosed pools. This may be due to the high chlorine level within the cell.
And as a person with 2 girls and a Mrs with thick hair, they still get knots and tangles, but it is far less. Their hair was like razor wire when we went to the neighbors chlorine pool all the time prior. We even had to have special shampoo designed for 'pool hair'.
Thank you Dirk. I will try to use the TFP lingo in the future. Also I appreciate the additional information.Just want to point out... the terms TFP uses are: "SWCG Pool" and "Non-SWCG Pool" not "chlorine pool" and "salt pool." See here. And that's because an SWCG Pool is a chlorine pool. The difference is whether the SWCG adds the chlorine, or you do.
What might be the reason folks are liking the feel of their SWCG Pools better is: you can generally cut back on the amount of chlorine in the water.
There's a few reasons for that. Here's two:
(1)
From that link above:
(2)
An SWCG dispenses chlorine about every hour, for most of the day, every day. The FC level is virtually constant, and only at the level you need to maintain your water. When manually dosing, to cut down on the lugging, most folks tend to pour in a bunch of chlorine, goosing the FC level higher than is needed, to extend the days between dosing. So the chlorine level is high for a day or two, then about right for a while, then low just before it's time for another dose. Or worse, to make sure their FC level isn't too low at the end of the cycle, folks will goose the FC even higher at the beginning of the cycle, which means for a lot of the days, the chlorine level is much higher than it needs to be. And that generally equates to that yucky "chlorine feel" that folks want to shower off.
I was uncomfortable after swimming for the few days following the pool guys visit. I know he was adding both a lot of chlorine and a lot of acid, so the pool would be "OK" until his next visit. But I would still get patches of algae on the walls. So not only was I not liking the water, but it wasn't all that safe towards the end of the week. Since adding an SWG and following TFP practices, I no longer get that skin irritation, and I haven't seen a spec of algae, ever.
Not to get too deep on ya... I liked the idea of this even-steven FC level all day every day so much, I added a second gizmo that dispenses my muriatic acid in much the same way (skin irritation is more often incorrect pH than FC). So that also contributes to the comfort of my water, because I no longer pour in a bunch of acid on Monday to get through the week, it gets metered out in very small amounts using the same schedule my SWG uses, so both my FC and pH are very stable/constant 24/7. But more on that when you're ready. First things first...
@Newdude and @YippeeSkippy ... Yeah I concur. My daughter has very sensitive skin, eczema, special creams etc. the whole thing. She got a job at the local pool teaching swimming lessons but had to quit because the water was to hard on her skin. She has no issues with swimming in our SWG pool since we converted. And the cadre of neighborhood kids that rotate from one pool to another for swim overs, say our pool is the best one, least irritating, best feeling, of all the pools in the area. We are the only one with an SWG. I'll admit there is not much science in the survey, but I'll take it!
@genlee if you read around the SWG related threads you find explanations for why SWG pools have a slightly different chemistry to create that effect. the thing that sold me on an SWG generator was the amount of time I saved managing my pool. I wasn't expecting that the constant creation of CL would make all the other pool chemistry more stable and easier to manage. If I calculate the amount of time I saved into that equation, I paid for the SWG in the first year. (I bill hourly so I know!)
