Why is my skimmer doing this...
IceShadow
2,177
Milwaukee, WI
The water is being sucked into the skimmer port faster than it can get through your skimmer throat. Likely for one of the reasons in the post above. :)
DreamFamof4
7
Michigan
My skimmer uses that type floating weir as well (but no weir door). Generally if I rotate the inner circular float all the way to its operating position it fixes it. If the inner float is closer to the release position such as when cleaning it seems to get partially stuck on the inner plastic notch.
