Hello all,
I bought a house in the fall of 2016, becoming a first-time pool owner. I've since learned a lot about the care and maintenance of above ground pools, including the winterizing and opening, from this forum and now I have another question.
My pool (it is a 4' deep oval) is surrounded by a large 60' x 40' deck. The piping for the filter system comes from the pool, travels straight for a short distance, then goes back up and over one of the joists for the deck before dropping back to the previous level and finishing at the filter. I have attached a crude sketch of it. I only included one pipe on the drawing, but both pipes (which are PVC) travel the same path.
I can't figure out if there is a design reason for the pipes to go back up and over the joist? From a performance standpoint, it causes issues sometimes - we have to keep the water level high up on the skimmer because if we don't, the pipe becomes the high point of the system and we lose suction/filtering. When the return line was installed, the previous owner hand tightened it (or less) and it constantly drips. I haven't bothered with it up until now, but I plan on fixing it before opening the pool in a few weeks and I'm wondering if I should re-do all of the piping so it comes out of the skimmer and straight to the filter instead of up and over a joist?
Mike
Mike
