Why 4-6 ppm FC for SWG?
Neworldjef
27
Monmouth Junction, NJ
Hi All,
Been part of TFP for years and have a good degree of mastery of chemistry. I'm wondering the rationale for recommending 4-6 ppm for a pool with SWG? It definitely seems to take color out of my liner quicker than when I kept levels of FC at 1-3 ppm. Wondering the reasoning so I can decide with my new liner (next season) how high I want to keep it.
Thanks!
Jeff
mknauss
44,848
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Based on CYA level. Target is essentially 7.5% of CYA. Minimum is 5% of CYA.
Liner should not be effected at levels below SLAM level.
Neworldjef
27
JJ_Tex
2,539
Prosper, TX (DFW)
Yes, and it also recommends keeping your CYA at 70-80 and even states:
Second adjust CYA to between 70 and 80. The biggest mistake that many SWG owners make is NOT having enough CYA in the water!
What is your CYA level?
Regardless, FC should be proportionate to your CYA. If the ratio is too high or too low, you can have issues.
mknauss
44,848
Laughlin, NV
Fiberglass
I read here a while ago that the newer liners need higher than minimum calcium levels or colors fade quicker, affects blue more.
Older liners. The newer vinyls do not require the same level of CH nor use the pigment that fades.
Reactions: Neworldjef
Neworldjef
27
Keep my CYA in that range. Just wondering about the liner fade most of all. Seems from what others write here. older liners used pigment that would fade. Maybe that is all. Although my previous liner of 12 years did not fade this quickly and my current liner is when i started SWG and FC 4-6...
TexEdmond
519
Edmond, OK
Pentair Intellichlor IC-60
Who can forget the immortal words of the late, great Merle Haggard?
"I wish a Ford and a Chevy (and a pool liner) would still last 10 years like they should... Is the best of the Free Life behind us now, and are the good times really over for good?"
borjis
3,508
Pacific NW
You might check for iron in your water.
Light staining can make the liner look faded.
My liner is much less blue than it used to be.
An ascorbic acid treatment returned the blue. I'd literally forgotten just how blue it was.
