I have a white film on my water. They average about the size of a pencil eraser. When I try to trap them in my hand they dissolve. I thought at first it may be air being sucked in at the pump but it doesn’t show up at the return. I don’t have a ladder or light for algae to accumulate around. I added bleach this morning and it seems to be getting a little better. I test with the Taylor K-2006 with all new chemicals. That brings up another question. When I add the R-11L to test for Calcium Hardness, it says in the instructions that the sample will turn red. The 11L is blue and when added it turns a light purple and then blue when the R0012 is added. I didn’t know If Taylor changed something in the R11 to be purple instead red or if something else is going on. I have a 33000 vinyl lined pool. I use bleach and also an automatic chlorine puck feeder.
Ph. 7.6
Chlorine 12.2
CC. .2
TA. 110
CH. 120
CYA. 35
Temp. 85
Ph. 7.6
Chlorine 12.2
CC. .2
TA. 110
CH. 120
CYA. 35
Temp. 85
