White fiberglass pool steps are brown
mknauss
36,066
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Add baking soda to raise the TA to 70 ppm. That should raise the pH.
Try vitamin C on the steps. That will tell you if it is iron.
Reactions: Jesusfreak
mknauss
36,066
Laughlin, NV
Fiberglass
How did your pH go 'through the roof' from 6.8?
mknauss
36,066
Laughlin, NV
Fiberglass
That is an issue. Start adding acid. Lower the pH to the 7's.
mknauss
36,066
Laughlin, NV
Fiberglass
I get mine at Home Depot. Some get it at pool store.
mknauss
36,066
Laughlin, NV
Fiberglass
If it is widespread, then you need to do an Ascorbic Acid treatment. And then either attempt to capture the iron before it re-stains or use a sequestrant.
