White deposits on outside of spa and waterfall
abradleydvm
62
Denison , tx
Hello all . I follow TFP methods ... you should be able to view my numbers on pool math and my signature should have my pool specs .... I’ve not ever had the deposits on the outside of the spa before ( just on the spillover ) . I would appreciate any and all advice . 😊
ajw22
23,657
Northern NJ
Pentair Intellichlor IC-60
Reactions: JamesW
JamesW
23,247
Water is seeping from the tub through the wall.
It could be from the tile, plaster or plumbing.
abradleydvm
62
Denison , tx
I assume this means water balance is not the problem and this is a structural problem ?
Is this a normal problem for hot tubs made with stone?
Should I call the pool company ?
cowboycasey
5,256
Southern OK
gunite, plaster, tile and grout are not waterproof, they let small amounts of water through constantly... When stone is done like that it should have 1 or 2 layers of waterproofing done under the stone to prevent efflorescence..
Until it is fixed it will look like that... You may use some CLR to see if you can get some of it off but it will return... I would not do anything until the builder see's what is happening and comes up with a solution..
Reactions: abradleydvm
