FC 3.8
PH 7.6
CYA 20
TA 220
CH 30
Ok here it goes, pool was completed on last Saturday,pool builder had his guy clean it which was vacuuming it several time and cleaning filter. Told me to run pump for 7 days 24/7 and clean filter everyday. Between Saturday and Tuesday I checked my pool chems and cleaned filter several times pool was very clear between this time and only got better since Saturday. I knew my cya was 0 due to filling from city water and I knew my TA was high at 230. I took a sample by Leslie and they confirmed this. They gave me liquid stabilizer which I added 2 quarts and 1 cup. I addressed the high TA by lowering PH did lower and so did TA but the TA crept back up. I also added a total of 14 pounds of calcium chloride between Sunday and Monday to raise CH. After adding all of this I was golden and pool was clear and I was on track. Tuesday night I got the bright Idea to stop my pump for the night and I woke up on Wednesday and found the pool very cloudy. I turned the pump back on and when I came home for the day Wednesday pool was looking more or less clear. Only problem is when the water is stirred up there is a fine white milky substance all over the side of the pool and on the bottom. Is this from the calcium chloride I added? What do you guys think is causing this. Is it still concrete work and fine particles in the water from construction? This is not just a little white film its a lot.
PH 7.6
CYA 20
TA 220
CH 30
