which test kit?
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
Hi everyone
long time reader and only second/third time poster
Please, I need some advice on which test kit to use. First time pool owner as of march 2018
It's a residential pool, in hot phoenix, AZ. Temp is 90 right now. Pool approx 20k, inground.
I saw the link that show the tf100 will provide more tests, but I really don't know. The wife and I are the only swimmers, pretty much ever weekend.
Any advice would be great!
Thank you!!
Jhsparky82
90
Appleton WI
CircuPool RJ-45 Plus
Pools need regular testing and maintenance no matter how many people swim in them. Ultimately, you get what you pay for.
I got the tf100xl because I had a swamp to start the season. If you have clear water, the XL isn't necessary. Everyone loves the speed stir. I don't have it, but it's still nice. The biggest thing for me was downloading PoolMath. In conjunction with a solid test kit, algae doesn't stand a chance in my pool.
ajw22
29,152
Northern NJ
Pentair Intellichlor IC-60
hi yes I plan on following TFP methods.
Just not sure which kit I should purchase between the two
does it not matter? I would like more bang for my buck.
Also, do i need the additional add ons?
TF100 is the better value. Get the speedstir.
You may want to get the CYA and some other standard solutions to practice on.
You have a SWG and need to do salt testing?
Btw, please Read This BEFORE You Post and complete your signature with your pool details. It will save asking you many questions.
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
so am I better of with the k-2006c XL?
ok will do
what is the speedstir?
sorry to get off topic ( i just ordered the kit) and will start a new thread if need be
But the bottom of my pool appears to have a thin layer of dirt that keeps coming back when i brush every morning.
Could this be dead algae?
Btw, please Read This BEFORE You Post and complete your signature with your pool details. It will save asking yiu many questions.
ok will read right away
I do not have a SWG
hi the water is crystal clear beside the annoying brown dust and/or algae that is always on the steps and sometimes in the shallow end
mknauss
44,426
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
When you get your test kit post up a full set of test results.
It is likely the 'dust' you speak of is dead algae. I doubt your pool is as clear as what you will soon see using TFP methods.
To update the signature, go to Settings, upper right of this page, then Edit Signature, left side of page.
jblizzle
43,238
There is no K-2006C XL.
There is the K-2006 (not enough reagents)
There is the K-2006C (too much of some of the reagents you do not need)
There is the TF-100 (a good amount of reagents as it was designed for the TFPC)
There is the TF-100 XL (just adds extra chlorine testing reagents which are needed if you are starting with a green pool).
The TF-100 is the best value and the one I would recommend.
The SpeedStir is a contraption that swirls the water for you making the testing easier ... I also recommend this.
This is all laid out in the Recommended Test Kits chart
Jhsparky82
90
Appleton WI
ok signature updated and tf-100 purchased.
on a side note, I do not own a vacuum. I have an automatic pressure side hayward vac.
Do I need to invest in a vacuum or should I wait?
I have a hose and weighted vac head, and I just vacuum to waste when I need to. It's a cheap, but effective solution.
ajw22
29,152
Northern NJ
Your side note is confusing. Do you own a Hayward pressure side vac? Or just have the pump and plumbing to a dedicated return in the pool?
You need something to clean the bottom of the pool. It could be:
- Manual vacuuming through the skimmer suction
- A pressure side Vacuum like The Polaris 380 that I use
- Or a robot cleaner
There is a section devoted to Pool Cleaners
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
hi sorry again new to all this.
It's a Hayward suction side vacuum
ajw22
29,152
Northern NJ
Pool Vac XL
OK, you have it. Have you used it? What is your question about it?
Please add that detail to your signature.
should I invest in a manually vac so I can vac to waste?
maybe I am getting ahead of myself
No reason to. Vacuuming to waste will just dump out water.
You will need to clean your sand filter occasionally to get rid of what the cleaner has suctioned up. Note your clean filter pressure and clean the filter when pressure rises by 25%.
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
updated signature with vacuum info.
Was not sure as I read I would need it to get rid of dead algae.
I run the cleaner everyday for 8-10 hours
I run it on 3 different speeds throughout the day and keep note of what the pressure is on each speed.
Thank you so much for all the information so far
