Which heat pump to buy for 3000 G AGP?
OlympicKnight
11
Olympia, WA
Hi everyone,
Which heat pump should I get for my 3000 gallons Bestway AGP? I am not sure if I need to worry about R32 (refrigerant) and DC inverter technology.
- Raypak crosswind 33k, 44k, or 61k BTU
- FibroPool FH120 Above Ground Heat Pump $1370 (120v will work with current outlet without any additional expenses). I'd install this one myself to save money.
- Some other brands?
How much does cost to install a heat pump? I'd have to install a new outlet and new wiring from the main breaker for 240-250v.
FYI, I will be heavily insulating the pool - on all sides. I already have R-10 XPS foam boards on the bottom. I am planning to make an R-10 XPS top cover as well.
I am planning to upgrade to a bigger pull in the future once kids a little older.
Thank you.
cowboycasey
8,647
Southern OK
CircuPool SJ-40
The only other one I know is the Aquacal T55 but it may be too big??
