Which diameter PVC for a long run?
Ryfq
7
Hendersonville, TN
Hello all.
I'm looking to hard plumb our pool this year. I've been scouring all of the great information on here (there is a TON). One point I keep flip-flopping on is what size diameter PVC to use. The PVC run will be around 60' in length. I see most people say 1-1/2 is plenty, but then I see things about keeping water velocity below 6ft/sec on the suction side. Unless I'm confused, this may warrant 2" PVC because I think my 1.5 HP pump may be oversized for our 18' AGP. Hopefully one of you smarter people can help me out on this one. Here are the relevant details:
18'x54" Saltwater 8000 Round Pool
Hydrotools Cartridge Filter System 1.5HP Pump
PVC run length: 60'
Pump will be approx 3 feet higher elevation than pool.
Thanks very much.
mknauss
37,031
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Your pump is an Above Ground pump system. It is not self priming. So the pump must be located below the surface of the pool water to operate.
Ryfq
7
Hendersonville, TN
Right. I guess I got a little hasty in throwing measurements around. I was measuring from the ground at the base of the pool where it sat last year. So the pump will actually still be at least a foot below the surface of the water.
JamesW
23,910
1.5 hp is too much for a single skimmer.
I would have at least two skimmers with 2" pipe to the pump or downsize the pump to about 3/4 hp.
Ryfq
7
Hendersonville, TN
Ok. Thanks. I don't think adding another skimmer would be a good option. So with a single skimmer, a 3/4 hp Pump, 1-1/2" PVC would be good? Or still 2" with 3/4 hp pump?
JamesW
23,910
I would do a 3/4 hp with 2" pipe or maybe a 1 hp two speed and just use the lower speed.
