If we look just at the plumbing and assume a worst case scenario with a single PVC pipe 100 foot long (equivalent length) for suction and return, I get the following for the plumbing part.
1.5” PVC pipe. 0.01144F^2
2” PVC pipe. 0.003129F^2
2.5” PVC pipe. 0.00126F^2
So, it would appear that the plumbing is not that significant.
In most cases, the plumbing will be less than 100 feet for suction or return and there will usually be more than 1 suction and return.
Curves A, B and C are defined by their formulas.
It probably does not make sense to say that a defined curve is necessarily related to the plumbing size.
The real problem is with the equipment like a heat pump that is about H = 0.00628F^2 by itself
This heater is about H = 0.00333F^2
This filter is H = 0.00155F^2
These sand filters are about
S180T ....H = 0.0138F^2
S244T....H = 0.00862F^2
S310T....H = 0.00342F^2
y = 0.00139x^2 for this Nautilus DE filter.
y = 0.00139x^2, x from 0 to 120, y = 0 to 25 - Wolfram|Alpha
Wolfram|Alpha brings expert-level knowledge and capabilities to the broadest possible range of people—spanning all professions and education levels.
www.wolframalpha.com
