When to run pump (day vs night)
rjmac
25
I'm a new BBB-er. We'd been battling algae for several weeks (lots of chemicals down the drain). I received the TF100 kit last Friday, began shocking on Saturday, and yesterday (Wednesday) I was finally able to clearly see the main drain in my pool. I've been running the pump 24/7, but now that it's cleared up, I want to back down to 8-10 hours per day. Is it better to run the pump during the day or at night?
Jill
benavidescj
431
Fleming Island, FL
It's personal preference. I run mine at night because I feel like it is less stress on my pump to run it out of the Florida heat. There are plenty of people who run it during the day also.
guamguy
388
Guam, USA
I've always been in favor of running the pump during the day. It helps keep the temperature in the pool constant throughout the water to minimize evaporation. It also helps by keeping the chemicals mixed up while the sun is beating down and using up some chlorine. If your electric rate drops at night, I would try pumping at night to save some $$$.
:cheers:
offgrid
87
Ottawa, Canada
Here in Ontario Canada we are going to peak and non-peak hours of use (Cost for hydro electricity). If I run the pump from 9:00 pm to 7:00 am I only pay 5 cents per KWhr. If I run it from 7:00 am to 5:00 pm it costs 10 cents per KWhr. (medium rates are 8.8 cents per KWhr)I will be putting my pump on a timer to only come on at night - I did this through the month of August and had no algae issues.
On weekends rates are at 5 cents per KWhr so we run the pump all weekend long. I read in the paper that Ontario may abandon these rates and make everything 1 rate. I'm not sure if any place in the US is experimenting with Electricity rates like this though. Maybe California ?
Bama Rambler
23,062
It's really a personal choice. I run mine a couple hours during the day just because I don't want it sitting stagnant for the entire daylight hours.
offgrid
87
Ottawa, Canada
My pool is about 20,000 gallons, how long do I need to run my pump to keep the water "clean". 8 hrs ?
I have the Hayward Aquarite Salt Chlorinator, Hayward 300 lb sand filter. I remember seeing a formula somewhere but can't find it.
Pool Temperature is staying around 75 with solar blanket on at night, and removed in the afternoons when it is sunny.
I was running the 1 HP Hayward Super II Pump 10 hrs at night and so far the readings Chlorine, PH, Alkalinity are perfect.
I have reduced to 8 hours and the readings are still perfect.... how low can I go ?
acroy
186
Dallas TX
I run it during the windy portion of the day, about 3pm-sunset. This helps keep the pool well skimmed & cleaned.
As far as "how long do I need to run my pump to keep the water "clean": just long enough to keep it clean! ;) Rules of thumb are something like minimum 1x per day turnover. I have been running about 0.8 turnover successfully all summer, with 85F+ water temp. Just have to keep an eye on it, don't let it get away from you.
Cheers
Bama Rambler
23,062
Acroy has the best answer "long enough to keep it clean!". Every pool and situation is different so there's no set amount of time or turnovers that are perfect for every situation. If 8 hours is doing it for you, you can leave it there or you could lower it to 6 and see if it stays crystal clear.
dmanb2b
3,734
NY
Assuming you are getting somewhere around 40 GPM it would be around 8.3 hrs....you would have to adjust for your actual GPM flow rate. :goodjob:
Bama Rambler
23,062
You have to know your flow rate. Multiply GPM by 60 to get GPH then divide gallons by GPH to get hours for 1 turn.
For instance if your pump flows 50 GPM and your pool is 20,000 gallons the formula is.
50 X 60=3000 then 20,000 ÷ 3000 = 6.67 hours for a full turn of the water.
crabboy
528
Suwanee, GA
Summer I pump during the day for about 10 hours a day. Sometimes it runs extra depending on the use. During the winter I switch the timer to run at night. I do this to minimize the overall pump time in the event of freezing temps starting the pump. I don't need it running during the day if it had been on for a few hours overnight. Also I only pump about 2-3 hours a day during the winter, it's long enough to keep it clean and the Polaris to do its job.
acroy
186
Dallas TX
offgrid said:
Thanks Acroy, Bama.
What is the formula for 1 x per day turn over with 20,000 gallons ?
Unless you know or can calculate your flow rate - I suggest start with 10hrs/day summer see how that goes for a week or 2, start going down from there until you get skeered ;)
Personally I'm at about 6hrs runtime, around $40/mo in electricity, and the salt cell can just barely keep up (only makes CL when the pump's running!). I could probably go down a bit more on runtime, but electric savings would be minor, and I'd have to start adding bleach to keep the FC up.
offgrid
87
Ottawa, Canada
Wow - Thanks everybody - Great tips..... temperature dropped to 71 F in pool last night so I ran for 4 hours - I'll check the Chemistry later today and report back.
offgrid
87
Ottawa, Canada
Ok - checked the pool chemistry after running pump for 4 hrs last night ....
Using Aquachek metre: I get the following readings .....
CL 1.3 ok
PH 7.3 ok
ALK 078 low
Guess I better run a little longer to get Chlorine up a bit ....
ginamarie88
11
i have been running my pump all day long all summer. I thought the pool store guy told me it was to run all day every day. I didn't know you could not run it for a few hours at a time. Is it bad to run it 24/7?
Bama Rambler
23,062
The only time I recommend running the pump 24 hours a day is if you have a 2-speed pump and are running it on low. On low speed the electrical uasge for 24 hours is about equal to 6 hours on high speed, plus you are circulating the water all day long. It doesn't necessarily hurt the pump to run it 24 hours a day but it sure hurts your pocket book to run it on high that long.
Other Threads of Interest
