- May 19, 2016
- 129
- Vinyl
- Liquid Chlorine
It Is early spring here and I have been running my filter for the last 10 days to clear up the cloudy water as much as possible before starting my daily dosing of chlorine to maintain my 4 ppm FC. Here are my numbers this morning:
Water Temp 55
FC 0
CC 0
PH 7.4
TA 50
CH 125
CYA 30
Usually when I open in the spring I have a green tinge to the water because I transfer my pool cover water into the pool to conserve water. So adding chlorine right away has always been a no brainer. This year I spent some time treating the pool cover water so it’s wasn’t as green when I transfer it under the cover. When I took the pool cover off the water was a bit cloudy but not green. As you can see from the attached photos, the pool is clear after running the filter.
My question is when do I start adding chlorine? When the pool hits exactly 60? Which I don’t expect it to hit in the next week to 10 days as the weather pattern here has the air temp at about 50. I have a supply of chlorine that will last me about 3 weeks of normal maintenance. As chlorine is not as readily accessible during the health crisis I am wondering when I should start bringing my FC ppm up? Any advice is much appreciated.
Water Temp 55
FC 0
CC 0
PH 7.4
TA 50
CH 125
CYA 30
