I've got the Aquarite system with a T-15. My salt level according to my Taylor test is at 3900 and the T-15 reads it at 2600. I know the optimum level is less than this. I have had to add salt to keep it at this level so it will continue to make chlorine. Once the T-15 senses that it is at 2600 or above it does a great job of making chlorine.
I have read other threads that have said this is symptom of a cell going bad. Mine continues to make chlorine great though.
I have also cleaned it within the past month and it doesn't seem to change anything as far as the sensor goes.
My question is when is it too much salt? Is 4500 ppm too much? And what will suffer with higher salt levels than recommended - swimmer comfort, plaster, the salt cell, etc?
Apologies if this has already been discussed.
