I have a question in terms of when you guys actually test your FC levels. This has always sort of confused me and I'm just wondering what others do.
I normally keep my CYA around 60. I get full sun on my pool from sun up to sun down. In terms of the CYA chart my target chlorine should be 7-9. I have a Stenner pump for my chlorine.
After the pump runs its course (and the chlorine is added) - about how long after that should I test my water? What should the FC reading be at that point given my CYA number? Should it be at the high or low level of the target? Should I test again right before my pump cycles on again the next day to see what the drop was??
Thank you!
Thank you!
