What would you say this pH level is?
Household6
450
Fayetteville, NC
Elevated.
What is the FC?
FC is Zero.
Seems to me the tube goes yellow, orange, pink so I was hoping this fell at 7.7 to represent red.
Never realized exactly how much aeration could affect pH! (Water level got low and have a jet that’s cracked allowing water to aerate. It has been a beast to get down!)
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,863
the colors going from low pH to high pH are
yellow 6.8 and lower
yellow orange 7.0
orange 7.2
orange red 7.4-7.5
red 7.6-7.8
red violet 8.0
violet 8.2 and higher
Your pH is 7.6
Reactions: Household6
JamesW
16,729
I'm seeing about 7.6. I think that most people read pH higher than it actually is.
You have to go by the hue more than anything else.
JamesW
16,729
It looks like 7.6 for both. Maybe get a pH pen if you want to be sure.
What's the TA?
Reactions: setsailsoon
JJ_Tex
497
Prosper, TX (DFW)
So, they are a little more of a pain to use?
I too have trouble distinguishing the PH in the kit and use the PH Meter to verify what I'm seeing. In my 1 week of use, I have not had to calibrate it at all, but its pretty darn easy to use. You turn it on, stick it in the water and it gives you the PH almost instantly.
JamesW
16,729
If a pH meter loses calibration and you don’t realize it it can lead you well astray. If you get pH readings you don’t expect you need to double check it with the OTO test.
OTO?
I think you mean pH reagent or calibration solution?
