What to get for replacing a temperature sensor cord? (Temp Sensor Open - Jandy Aqualink RS4)
dblko
Active member
Jun 20, 2012
42
The cord between the control board and the temperature sensor on the water pipe was accidentally cut somewhere in the middle.
I tried to splice it back together but its very brittle and old already and did not make good contact, so perhaps its best to get a new wire altogether?
Where to actually buy such a wire without getting a new sensor? And is it actually possible to attach a new wire on the sensor side?
The control board side seems simple as it has screw in terminals for the two leads.
Thanks !
chiefwej
3,724
Tucson
Go to your local hardware store and get some bell wire. It might be a bit stiffer since it’s usually sold copper, but it will work fine.
Reactions: dblko
PoolGate
6,359
Damascus, MD
Jandy Aquapure 1400
Just get a new sensor they are cheap enough.
dblko
Active member
Jun 20, 2012
42
PoolGate
6,359
Damascus, MD
Jandy Aquapure 1400
A new sensor around $100 is not really that cheap, or perhaps its cheap considering what pool stuff generally costs:
Getting a new one comes with the added complication of removing the old unit and sealing in the new unit so that's its watertight.
They are simple to replace it comes with a new gasket/washer and connects with a worm clamp. Take out the old, put in the new. 1 plug on your Aqualink. If your cable is deteriorated that much the sensor is on its way out too. They don't last forever.
chiefwej
3,724
Tucson
dblko
Active member
Jun 20, 2012
42
