What kind of rope to use for weighted bottles of bleach tied to cover eyelet?
jlt19
47
St. Louis, Missouri
I plan on blowing up 2-4 inner tubes and using them to create a runoff system of sorts to prevent heavy water retain-age on the winter cover.
Then I plan on tying bleach bottles to the eyelets to keep it weighted down.
Any suggestions on what kind of rope to use or ideas/hacks on how to make it as non-tedious as possible?
Also:
I'm closing early for a variety of reasons, so will be using Polyquat 60. My CYA is high, so SLAM level is 47, reg FC is 15.
Currently at 17.5 (as of yesterday) and while I was losing 4 ppm a day, with our weather lowering a bit, it was only 1 from Monday to Tuesday.
I am closing on 10/6/19. If I bring it to SLAM tonight (47) and continue to lose 4ppm, I'll be at 11 when adding the Polyquat. Is that too high?
It's possible if I bring it to SLAM tonight that it could be significantly higher, possibly still in the 30's!
Do I need to SLAM it first? Actually just coming off a SLAM and still haven't naturally hit my target 13-15 as is.
If no SLAM, what's the target FC for adding Polyquat? Does CYA matter in that case?
Bama Rambler
23,698
I use ball end bungees to support the bleach bottles on our cover. I only fill the bottles about half or a little less full. You may have more wind in MO than we do here, so you may need them a little more full.
Reactions: jlt19
