Hi,
After the 28 day startup I had been able to keep the pool quite balanced. I went about 2 weeks without stabilizer (had it ordered online and waiting for it to arrive). The water was so crystal clear that with goggles i could see across the 37 foot pool as if there was no water in it. It looked stunningly clear. This is what it tested as during those 2 weeks
FC: 0.5 to 1.5 ppm
CC: barely changed color when adding the R0003 - probably 0.1 or 0.2
Calcium: 325
PH: adjusted every 5-7 days from 7.8 back down to 7.4
TA: 70-80
CYA: around 10-20 from some tri chlor pucks the PB used during the startup
Salt: 3600
Then I added a 4 lb of stabilizer, separated in 2 doses over 3 days which got the pool to CYA to around 60. I didn't want to go higher yet, just in case I needed to shock. I manually incrase the FC to 4.0 one time and then over the next week adjusted the SWG to maintain approx 3-4 FC.
This was 3 weeks ago and since then we have had quite a bit of rain, I had to drain the pool by 1-2 inches twice. There has also been quite a bit of organic matter that blew into the pool (dirt, sand, leaves, mulch). The water still looks great when you are looking at it from above, but with goggles underwater, I have lost that exceptional clarity.
Here are my test min/max from the past 2 weeks
FC: 3-4 ppm
CC: always measures at 0.5 but the color is now much darker when i add the R0003 - there is also a slight chlorine smell after swimming
Calcium: dropped by 25 each week down to 275 (due to draining)
TA: 70
CYA: 50
Salt: 3200 (dropped due to draining the pool)
My main question: Is this mainly a problem of all the rain and organic matter that blew into the pool plus the rain water? Or did I mess up the balance by adding the Stabilizer and should have aimed for a higher FC?
What is the best way to get my water as clear as it was again and get rid of the CC which leaves the very light chlorine smell on our skin after swimming?
FC: 0.5 to 1.5 ppm
Calcium: 325
TA: 70-80
Salt: 3600
FC: 3-4 ppm
TA: 70
CYA: 50
