What is this noise? New motor, old housing/impeller/diffuser
racharoow
77
Southern NH
Did you replace the seals when you replaced the motor?
Did you inspect the impeller and diffuser when you had it all apart?
Yes and yes. The shaft seal was replaced and any o-ring that was part of the assembly was replaced (with the Into "go-kit"). The diffuser inner ring felt a little rough, but I was told some wear there is expected. Impeller didn't appear to be damaged or worn in any way.
ccbill
139
Atascadero, Ca
Does your new motor horsepower match the pumps *original* horsepower? (The impeller is the correct size for the new motor?)
Could there be something bouncing around inside the wet end of the pump?
racharoow
77
Southern NH
The new motor is a USQ1102 (1 HP). It replaces a 1 HP STA-RITE motor. I consulted with Inyo before making any purchase.
The noise in the video above is the noise that made me replace the motor. Clearly, it wasn't the motor making the noise... though the old motor was 11 years old so it was due for a replacement.
ferretbone
In The Industry
May 24, 2016
164
tx
Turn the pump off open the lid remove the basket and spin the impeller using a small screw driver. See if it makes any sounds while spinning that way. The impeller or diffuser could be a little lose. If the diffuser has a screw missing on one side it could make a noise like that. Feel the pump and see if it's bouncing on the pad. Lots of small air bubbles can also make strange nosie.
To me it sounds like the diffuser or something is vibrating.
Reactions: racharoow
racharoow
77
Southern NH
I'll give that a shot once it stops raining. Thanks!
racharoow
77
Southern NH
I went over lunch and checked it out. I can turn the impeller with a screw driver, but it doesn't spin more than the amount that I push it with the screw driver. Is that expected?
I managed to get my phone in there to take a photo. Doesn't look normal, does it? The motor is also very hot, almost too hot to touch for more than a few seconds. I also grabbed another video showing how the noise gets louder once the system has finished priming.
ccbill
139
Atascadero, Ca
That picture is looking into the diffuser at the impeller? If so, the impeller looks off-center. Is the diffuser flush with the seal plate - no gaps where its screws into the seal plate?
Reactions: borjis
racharoow
77
Southern NH
That picture is taken from the basket area, pointed back towards the impeller. The camera might not be centered in the basket area, leading it to look like something is off center.
I will take the assembly apart and make sure it's all sorted. Thanks
Poolbreh
In The Industry
Jul 31, 2021
300
San Diego
Your impeller is grinding on one side. You’ll need a new impeller and diffuser. When you take it apart make sure the motor can sit flush on the seal plate housing. If it’s cocked you may need a new seal plate. If it isn’t addressed you may run into the same problem with new parts. 1632861823423.jpeg
