What has just ruined my pool? Pump? Heater?
Randomguy81
Active member
Jan 1, 2020
39
Jensen beach Florida
I came back to a pool green and full of rust (had a service Tuesday and no issues). Took apart the pump and found rust inside
I’m slowly going insane just looking at my 8 month old pool that’s screwed
can I recover my pool / remove the rust marks? It’s not even a year old
Jimrahbe
20,931
Bedford, TX
81,
Why do you assume it is the SWCG? SWG's are not magic, they still require you to test and ensure your water is balanced. If the pool turned green, it is pretty obvious that the pool was not kept balanced..
What do you mean you "had a service Tuesday"???
Tell us more..
Note.. I see you have several CircuPool items, so not sure which one you are talking about.. :scratch:
Reactions: Mdragger88
Randomguy81
Active member
Jan 1, 2020
39
I haven’t taken the pump apart fully yet but I’m going to hazard a guess that there is a ton of rust back there - I can clearly see it has pumped out of the jets as there is a clear line. I can only take an educated stab at the pump being the guilty party.
JamesW
23,450
The motor shaft won’t be exposed to the water unless the seal is leaking.
So, you have a shaft seal leak that will rust the shaft regardless of the water chemistry.
Some salt contains iron. So, that might be the source of iron.
All water from natural sources has iron. Your city water has iron; it just depends on how much.
Well water can have significant amounts of iron. Do you have well water?
What is the chemistry history from the fill date to now?
JamesW
23,450
Drop some vitamin C tabs on a spot to see if the iron clears up where the tabs sit.
If it clears, that indicates iron.
You can do an ascorbic acid treatment, but the iron just goes back into the water and it will eventually restain in anywhere from a day to 6 months.
If the iron stains showed up immediately after the service, it's likely that added salt was the source of iron or chlorine was added that oxidized the existing iron in the water into rust stains.
What was added during the service?
Dirk
8,624
Central California
Pentair Intellichlor IC-40
Take a deep breath...
If there is a solution to this issue (there very likely is), then the three experts that just showed up in your thread will be able help you find it. Just answer their questions, even if you don't yet see how that will help.
Meanwhile, I haven't read them, but if you use the TFP search field you can find lots of threads about rust and how to get rid of it.
Another deep breath... we got you...
Randomguy81
Active member
Jan 1, 2020
39
Ok I’m taking a breath
currently in Home Depot grabbing a temporary pump and a stainless brush so I can at least get the filter going
service - pool guy comes every Tuesday to clean and balance chemicals. Normally it’s a self thing but we have cancer in the family and I have been up in Delaware until today (great to come back to after a solid 15hr drive)
not on a well
I will have to ask the pool guy for the chemical history - he’s reputable so that’s one thing.
thank you to everyone being so responsive whilst I have a mental breakdown.
JamesW
23,450
The pump is not the problem. The only parts of the pump exposed to the water are not going to rust.
The rust that you see is due to a seal leak that has been happening for a while. It should have been noticed by the service person.
A service should be leaving you a written description of all work done, all chemistry and all chemicals added.
Was the pool good before the most recent service?
Try the vitamin C.
Randomguy81
Active member
Jan 1, 2020
39
If it’s a seal leak then the pump is the problem no?
will pick up some vitamin c tablets after Home Depot
anything else I should be picking up?
once again from a tired guy with upset kids that can’t swim after building it up for the 15hr journey home - thank you for your time, patience and knowledge
JamesW
23,450
The seal leak is a problem, but it is not the source of the iron.
Was the pool clean before the most recent service?
If yes, then it was probably something the service person did that caused the problem.
ajw22
23,986
Northern NJ
Pentair Intellichlor IC-60
What do you intend to use the stainless brush for?
Randomguy81
Active member
Jan 1, 2020
39
I had my neighbor switch on my pool heater last 2 days ago - could the heat have caused some reaction? This is the only thing that changed recently and the neighbor said they did not see any issues with the pool - they would (I hope) have noticed considering how bad it was
