It sounds a wired question. It is because I am trying to use two T104 on/off timers to control a two speed pump. I‘d like to use one timer to control low speed on from 4am to 10pm. Then I will use the second timer to have the high speed on between 1:00am - 2:00am.
However, I worry that the two T104 timers won't synchronize perfectly after a while and end up with the condition that both high and low speed of the pump are powered at the same time. As long as the pump is not damaged, I am ok with it messes up once every several months.
Thanks so much!
Thanks so much!
