What do you use to measure/ add
mknauss
44,825
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
In your volume pool, you really do not need to measure that precisely. Use a 1/4, 1/2, etc of the jug.
But if you insist on measuring, use plastic measuring tools. A 4 cup one is good. Should have one for acid and one for chlorine to be safe.
Reactions: PatricksPool
HermanTX
2,747
Katy TX
I found a plastic container that I marked off in 8, 16, 24 and 32 oz. I always add in those increments. I have 2 - one for acid and 1 for chlorine. It does require you to handle the acid twice but I find it better then trying to hold a gallon jug of acid over the pool to pour in.
You can find something similar at Home Depot in the paint department.
Homebrewale
638
Apex, NC
While it may not matter with chlorine, muriatic acid additions are less than 1/4 of a jug or similar measurements. Also when my measuring cup is dry, I use it for dry measurements like CYA. I put it on my home scale and weigh out the amount I need.
Pmachang
18
Richmond Hill, ON, Canada
Hayward Aqua Rite (T-9)
Not sure what type of shock you used but suggest go with liquid chlorine or cal-hypo (since you have a vinyl pool) to quickly raise your FC if needed. I would err on the high side of your target FC which for CYA of 70 is 5-10ppm so maybe go to the 8-10 range to rid yourself of any lingering algae.
Is it okay to use a glass measuring cup instead of plastic?
Kevinr14
296
Chandler, AZ
I have a 2 cup plastic measuring cup for acid and a 1 gallon measured pitcher for chlorine. I know you don't have to be that precise with the acid but I have to be for my OCD to be satisfied.
Lilypad
375
Plano, Texas
I also pour straight from the bottle....both chlorine and muriatic acid. I prefer not to transfer
chemicals to another container if at all possible. Only handle it once. Lower jug halfway
into the water, tip to pour, cap it, dunk to clean and done.
I'm not worried about slightly overshooting the FC. Since I "know" my pool’s appetite, I tend
to go slower on the MA and adjust as needed as I test. Usually right on the mark, which is totally
satisfying!
Reactions: Kellyp and mknauss
