What chemical to use first
Detour
13
Felton/ Pennsylvania
New here and I wish I had been a longtime ago
Just refilled my pool with Spring water because CYA was off the chart. FC 0 TA 30 PH very low CH 120 CYA now 30. Should I use soda ash to bing both my TA and PH up or start with Borax
woodyp
11,350
East Texas
Adding borax to raise your TA will also increase your ph some. Sneak up on your target number and retest.
Richard320
23,933
San Dimas, CA (LA County)
I think Woody was having a brain fart. He meant Baking Soda for the TA.
TA first, with baking soda. Otherwise pH swings can get wild. To about 50. Then see what happened to pH and fix it with Borax. Then fine tune TA if it needs it.
But if you already have the soda ash, then use that. You'll be juggling two parameters at once, so it gets a little more complicated. Work up to your target pH. Call the pH 7 and target 7.5. Wait an hour or two, then recheck and repeat.
Detour
13
My CYA is lower then 10 ppm. Does any body know how much granular Clore Bright to use that has dichloro in that got me in trouble before I found this website. Don't want to overdo it but get a rough idea before we check CYA again. Also I still need to use Algae Control 60% to prevent algae even when using bleach.
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
At the bottom of PoolMath there is a section called Effects of Adding Chems where you can enter the amount of a chemical and it will tell you what it will add to your pool.
spinPHD
501
Phoenix
I would recommend that you buy stabilizer separately to get your CYA up to 30. Trying to raise CYA with products that also raise chlorine takes too long. Most likely it will end up costing you more in reagents than you would just buying stabilizer, because you're constantly testing to reach your CYA target.
Detour
13
Teald024 yes that was a question. I'm still work on FC and CYA, Pool math is still telling me to rase my TA it's at 90 with in range. I don't what to get to the point where I have to use acid again.
Thanks to every one
Richard320
23,933
Thanks to every one
Then change your Target TA to match your Now TA and it will stop doing that.
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
Change your target TA to 90 and it won't tell you to raise it anymore. Use acid to lower PH to 7.6 when it rises to 8.0.
No to algaecide except when closing your pool. And make sure it does not contain copper. I don't close my pool, we're on season 6 with this pool and I have never put algaecide in it.
Detour
13
I hate to admit it but I been a pool owner for years. I most be get smarter the older I get LOL but I finally found this site and still learning the correct way. ����
That was supposed to be thumbs-up not?'s
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
Hey, that's what TFP is here for! I still learn new things some days. :thumleft:
The forum doesn't always play nice with outside emojis.
Detour
13
My next investment is to get a solar blanket that I haven't used in the past couple years. I have two sets of sun solar heaters that I've been using. I'm thinking about going with one now mainly to keep cover at night. I've been doing some research and they all have good and bad reviews. Anybody have any suggestions to where to buy and color and ml thickness. I'm thinking 12 ml not to thin not to thick.
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
A solar cover will make a big difference in slowing overnight heat loss. Actually we recommend the thinnest, cheapest cover you can find. Thin because it is easier to handle due and cheap because they only last 2-3 years no matter how thick they are. A solar cover works by stopping heat loss through evaporation, mostly at night. Anything that stops evaporation will also stop heat loss. There are blue and clear, get whichever color you like better.
