I had a pine cone stuck in skimmer line and pool was not circulating for a week and turned green. I blew out clog and now starting my SLAM. Issue is that I have no CYA. I filled tube to the top and can still clearly see dot. Do I bring CYA up first then start SLAM or what? All numbers are way off. If I start SLAM first, how do I know what target chlorine to use since chart is based on CYA levels?
FC 3.0
TA 40
CYA likely 0
PH higher than 8.0. Was dark red
FC 3.0
TA 40
CYA likely 0
